Leuk ding was dat en erg snel!
Specs:
Megabusa
Available as: Factory built, Complete kit (less engine gearbox wheels and tyres) and Starter kit
Engine: GSXR1300R Suzuki Hayabusa
Capacity: 1299cc
Cylinders: 4
Bore and stroke: 81.0mm x 63mm
Fuel: 95 Octane unleaded
Compression Ratio: 11.0:1
Valves: 16V
Exhaust control: Catalyst
Camshaft: DOHC
Ignition system: Electronic ignition & Suzuki throttle bodies
Max Power: 180ps @ 9800rpm
Max Torque: 138.29 NM @ 7000rpm
0-60: 3.48
Transmission: 6 speed constant mesh
Primary reduction ratio: 1.596
Final drive: 3.36/3.21 optional LSD
Steering: Rack and pinion
Lock: 2.5 turns
Brakes: Disc brakes all round
Wheels: 13 Aluminium
Tyres: 205/60X13
Fuel Tank capacity: 28.4 litres
Suspension: Fully independent wishbones front and rear with adjustable shock absorbers
Overall Length: 3340mm
Overall width: 1610mm
Weight: From 440kg
[Chassis]
Westfield SEi Wide body '99 chassis - heavily modified to accept 2 engines and provide sufficient strength and stiffness to cope with the increased power. Caged FIA/MSA Homologated T45 Roll Cage.
[Engine(s)]
2x Kawasaki ZX9R type B engines & gearboxes. 2x Tony Law exhaust manifolds and silencers.
[Transmission]
Z-Cars transfer box to combine and transmit drive from the two six speed sequential boxes to Quiafe ATB and also provide reverse gearing. Fitted with pumped oil cooling circuit and bearing retainer mods. 2x Bailey Morris custom propshafts, with torque tubes.
[Misc]
TAS 2.2 turn quick rack. Widetrack front suspension. Wilwood 4 pot front brake calipers, with 280mm vented cross drilled discs. Adjustable brake balance. Willans 4 point harnesses. RFX Revolution 15"x7" front, 15"x7.5" rear split rims. Toyo Proxes T1-S 205x50 front, 225x50 rear tyres.
[Performance & Figures]
Total power 314bhp, total torque 150lb/ft. 500bhp/ton, 0-60 in 3.5seconds, 0-100 in under 8seconds and a top speed of 145mph
Gaskleppie wrote:De motor draaid dus zo'n 12.000rpm max. als de civic met z'n 4 bak bij 4000rpm zo'n 100km/h zou halen (gokje, klopt dit een beetje?) zou je dus met de cbr motor een top van 300km/h halen........ :shock:
Beetje veel dus..... dan kan je beter op zoek naar een motor van een chopper ofzo. Die halen een lager vermogen maar wel een hoger koppel bij een lager toerental.
