The question: How many ITRs were sold in the U.S. market?
EDIT: The answer to this question has been copied into the end of this initial post. Look for the red heading.
The good news: It's possible to come up with a definitive answer to that question.
The bad news: It's going to take a bit of computer skills and a lot of time.
The background:
Between a previously posted letter and personal contacts, several of us have heard an answer to this question from folks at American Honda, that the numbers sold for model years '97, '98, '00, and '01 were 318, 1023, 1347, and 1157, respectively, for a total of 3,845 ITRs. But some folks here have been looking for documented proof of those numbers, beyond that already available. It is now possible to get such proof. Here's how.
Every ITR sold in the United States has a VIN (vehicle identification number) in the format JH4DC231cySnnnnnn where:
c is a check digit, calculated as shown on this web page, where it says "What is a Check Digit and how is it calculated?" (The examples and information shown are for NSXs, but the calculation itself applies to ITRs as well)
y designates the model year of the car (V=1997, W=1998, Y=2000, and 1=2001)
nnnnnn is a sequential numbering of the cars produced (that does not have ANY relationship to the ITR numbers on the armrests)
Therefore, it is possible to use a computer to calculate the check digit, and therefore the VIN, for all possible VINs for ITRs sold in the United States.
It is also possible to take each VIN and verify whether it was or was not ever a valid VIN for an ITR, by entering it into the "My Acura" section of Acura's website. The website will indicate whether or not it is a valid VIN, and if so, will also indicate the color of the car. If someone does this, he can compile a list of all valid VINs of every ITR sold in the United States, and identify the color of each one. This will give us a total number of ITRs and a breakdown by color.
The problem in doing so is that this process involves entering thousands of VINs into the website to verify which ones were actually ITRs. This will require a fair amount of work. In fact, it might be so much work that it's impractical; I don't know. More specifically, I don't know how high the VIN sequence number (that nnnnnn part of the VIN) goes each year. If there was one VIN sequence for all Integra versions, including two and four doors, GS-R and SE and LS and GS as well as ITRs, there may be so many possible VINs to check that it's impractical to check all of them. (Integras were selling at a rate of approximately 40,000 cars a year in the States when the ITR first came out in 1997, although that figure dropped to around 14,000 a year by 2001, as shown in the figures here; note that those figures show sales by calendar year rather than model year.) But if the ITRs were only produced in a small number of "runs" during the manufacturing process, it might be feasible to check only the ranges of VIN numbers in and around those runs, so that only a few thousand VINs for each year would need to be checked instead of tens of thousands. Unfortunately, I don't have any idea how to go about isolating which portions of the sequence number series would contain all the ITRs. EDIT - since originally writing this post, I found out that there are four sequences of USM Integra VIN numbers each year, and exactly how high they go for each year's sequence for manual hatches. See this later post in this topic for details.
If this sounds too complicated and impossible, it's not. Someone on NSXprime went through exactly this process to determine the VINs of NSXs sold in the U.S. in recent years, identifying each one by color, transmission, and body style. Granted, it was easier with NSXs because it was only a few hundred each year, all using one sequence of VINs with no non-NSXs mixed in, so there were only a few hundred to check without having thousands of GS-R or LS Integras mixed in (and again, I don't know whether or not that's the case with the VIN sequence numbers used for the ITR). But still, if it's possible for someone to do that with the NSXs, it's possible for someone to do that with the ITRs.
Maybe there is someone here (or several someones here) who might be interested in taking this on. Someone with the computer skills to program the algorithm to calculate the check digit for each possible VIN, and someone to spend the time entering the list of possible VINs into Acura's website to verify which ones were sold as ITRs (and find out the color of each).
EDIT - Added bolded sentences above.
EDIT - Added the answer below.
andyt posted the following answer to this question on page 5 of this topic. Here is a copy of that post:
Quote, originally posted by andyt »
Ok, here are the answers.
Total USDM ITR Production by Year
(numbers in parens are the previously accepted totals)
1997 320 (318) 320 CW (100%)
1998 1002 (1023) 1002 CW (100%)
2000 1355 (1347) 573 FBP (42%) 782 PY (58%)
2001 1173 (1157) 523 NBP (45%) 650 PY (55%)
Grand Totals by Color
3850 Total
1322 CW (34%)
1432 PY (37%)
1096 *BP (29%)
573 FBP (15%)
523 NBP (14%)
ITR Production Sequence Number Ranges by Year
1997
002516 - 002519
002819 - 002832
002835 - 002849
002861 - 002925
002927 - 002966
002970 - 003029
003037 - 003056
003066 - 003127
004247 - 004286
1998
000002 - 000003
002024 - 002071
002091 - 002114
002178 - 002225
002310 - 002333
002358 - 002381
002383 - 002406
002411 - 002433
002494 - 002516
002518 - 002540
002608 - 002630
002674 - 002721
002746 - 002769
002801 - 002824
002861 - 002884
002912 - 002935
002972 - 002995
002998 - 003021
003051 - 003074
003106 - 003125
003185 - 003205
003230 - 003250
003283 - 003287
003343 - 003363
003395 - 003402
003425 - 003431
003450 - 003471
003503 - 003524
003556 - 003577
003606 - 003627
003683 - 003699
003735 - 003756
003822 - 003830
003849 - 003870
003906 - 003921
003976 - 003998
004018 - 004026
004067 - 004075
004105 - 004113
004158 - 004166
004215 - 004223
004272 - 004291
004326 - 004335
004349 - 004358
004386 - 004395
004450 - 004469
004523 - 004532
004549 - 004558
004584 - 004593
004614 - 004622
004639 - 004647
004681 - 004689
004726 - 004734
004777 - 004785
004817 - 004826
2000
000929 - 000931
001163 - 001185
001200 - 001245
001276 - 001298
001323 - 001346
001369 - 001392
001408 - 001451
001481 - 001504
001518 - 001541
001557 - 001579
001602 - 001625
001647 - 001649
001663 - 001666
001679 - 001682
001692 - 001695
001709 - 001712
001719 - 001720
001725 - 001732
001740 - 001744
001752 - 001756
001762 - 001771
001773 - 001776
001791 - 001794
001806 - 001809
001824 - 001827
001866 - 001868
001895 - 001897
001911 - 001913
001935 - 001939
001983 - 001990
002021 - 002024
002065 - 002068
002100 - 002102
002167 - 002169
002208 - 002210
002233 - 002235
002302 - 002305
002345 - 002347
002361 - 002364
002416 - 002419
002461 - 002464
002501 - 002504
002550 - 002553
002582 - 002585
002605 - 002607
002675 - 002677
002716 - 002718
002757 - 002759
002771 - 002773
002804 - 002841
002843 - 002879
002893 - 002911
002920 - 002938
002964 - 002982
003020 - 003038
003074 - 003092
003109 - 003127
003132 - 003150
003183 - 003201
003228 - 003246
003266 - 003284
003302 - 003334
003361 - 003379
003865 - 003900
003946 - 003972
003989 - 004000
004052 - 004063
004096 - 004107
004153 - 004164
004204 - 004215
004231 - 004242
004281 - 004293
004334 - 004346
004362 - 004374
004389 - 004401
004419 - 004431
004443 - 004464
004466 - 004476
004513 - 004533
004536 - 004559
004590 - 004601
004627 - 004638
004662 - 004673
004682 - 004705
004712 - 004723
004738 - 004749
004765 - 004776
004786 - 004807
004831 - 004833
004840 - 004840
004856 - 004864
004900 - 004908
004936 - 004944
004964 - 004972
004999 - 005007
005030 - 005038
005067 - 005075
005100 - 005108
005116 - 005124
005158 - 005166
005222 - 005231
005245 - 005254
005265 - 005283
005295 - 005321
005325 - 005344
005379 - 005389
005429 - 005440
006891 - 006894
2001
000001 - 000094
000111 - 000135
000144 - 000174
000178 - 000222
000303 - 000346
000352 - 000386
000487 - 000530
000600 - 000634
000686 - 000691
000789 - 000789
000808 - 000858
000892 - 000892
000924 - 000953
001019 - 001086
001101 - 001150
001221 - 001279
001303 - 001322
001428 - 001453
001586 - 001630
001683 - 001719
001722 - 001808
001825 - 001887
001917 - 001941
001955 - 001989
002084 - 002105
002154 - 002182
002197 - 002222
002340 - 002367
002498 - 002520
002529 - 002556
002633 - 002688
003622 - 003625
Aantal ITR's in de states.
Zouden wij ook zo'n lijst hebben hier in europa?
In Nederland in ieder geval niet want dat heb ik meerdere keren nagevraagd aan Honda NL.
