Beroep; Rising Sun Performance
Woonplaats; RSP Garage
Motor
K20A2 EP3 Civic Type-R | 247,4HP & 252,6Nm
Hybrid Racing Custom Engine Mounts
Hybrid Racing Fuel Rail
Hybrid Racing Fuel Lines
Hybrid Racing Radiator Hoses
R-Developments Baffled Sump System
Rising Sun Performance K20 Header
APE :garage: 3" Exhaust System
Ape :garage: 3" Intake System
Blox Velocity Stack Air Filter
Karcepts Alternator Relocation Kit
AEM Fuel Pressure Regulator
Walbro 255 lp/h Intank Fuel Pump
SPAL Radiator fan
SRR Coolant Reservoir
Drivetrain
FN2 Civic Type-R Gearbox 5.062 Final Drive | The Stig Approved
ACT 6 Puck Clutch Disc
Hasport EF Shifter Mechanism
Hybrid Racing Shifter Box
Type-R Shift Knob
Prelude H22 Shifter Cables
Drive Shaft Shop Customized Drive Shafts
Electronics
Hondata K-Pro ECU Dyno tuned by Bekerom Tuning
Hybrid Racing Custom Wire Harnass
Autometer Boost Gauge
Autometer Narrowband Gauge
Autometer Oil Pressure Gauge
Autometer Oil Temperature Gauge
Autometer Water Temperature Gauge
AEM Uego Wideband Sensor and Gauge
Battery Replaced To Rear
Exterior
RSP Racing Matte Black
Aluminum Dual Wing
APE :garage: Stainless Steel Wing Support
Spoon Style Mirrors CF
Interior
Buddy Club Racing Seat
LTEC 3" 4 point Harness
Sparco L505 35cm Steering Wheel
Sparco Quick Release Hub
Suspension & Brakes
Energy Suspension Master Kit
Energy Suspension Trailer Arm Bushings
Öhlins Coilovers w Skunk2 Racing Springs
JDM DC2 98 Spec Brake Calipers
JDM Dc2 98 Spec Brake Pads
Nitrac 282mm Brake Discs
Volk GT-N 15" 6,5J ET45
Yokohama Advan A048 195/55/15
Testing/Racing on Time Attack 2010 @ Zandvoort, after this event we've changed the suspension, tires, brakes and wheel setup to mentioned above. We did not do any testing with the new setup yet.
Dyno Run on Vimeo:
http://www.vimeo.com/10048960
Onboard at Time Attack:
http://www.vimeo.com/10601993
