[quote="Gaskleppie"]Meneer AP heeft erop geschreven wat links en rechts is. Met meneer AP ga ik niet in discussie ]
Gaskleppie, je hebt gelijk, ik heb het verkeerd gelezen..
Source:
http://www.zeckhausen.com/how_to_proper ... rotors.htm
Slotted rotors
As with the plain rotors discussed above, the internal vanes should lean toward the back of the car.  The direction of the slots on the outside of the rotor do not dictate whether the rotor is a left or a right.
For rotors with slots machined in the same direction as the internal cooling vanes, the slots should lean toward the back of the car.  For rotors with slots machined in the opposite direction as the internal cooling vanes, the slots should lean toward the front of the car.  Bottom line - don't use the slots to decide which side to mount the rotor.  Pay attention to the internal cooling vanes.
For slotted rotors with straight internal cooling vanes, the direction of the slots is totally up to you and what you think looks best.  In this case, there is no wrong answer.
