I-VTEC
Posted: Sun Oct 15, 2006 9:00 pm
by RedSun
Ok, waarschijnlijk een domme vraag maar ik weet het antwoord niet.
Waar staat die I voor een waarom niet gewoon het klassieke:
DOHC VTEC bij de CTR?
Thx alvast.
Posted: Sun Oct 15, 2006 9:13 pm
by Gangaran
De "I" staat voor Intelligent VTEC.
Posted: Sun Oct 15, 2006 9:23 pm
Wikipedia wrote:i-VTEC
i-VTEC (The i stands for intelligent) introduced continuously variable camshaft phasing on the intake cam of DOHC VTEC engines. The technology first appeared on Honda's K-series four cylinder engine family in 2001 (2002 in the U.S.). Valve lift and duration are still limited to distinct low and high rpm profiles, but the intake camshaft is now capable of advancing between 25 and 50 degrees (depending upon engine configuration) during operation. Phase changes are implemented by a computer controlled, oil driven adjustable cam gear. Phasing is determined by a combination of engine load and rpm, ranging from fully retarded at idle to maximum advance at full throttle and low rpms. The effect is further optimization of torque output, especially at low and midrange RPMs.
For the K-Series motors there are two different types of i-VTEC systems implemented. The first is for the performance motors like in the RSX Type S or the TSX and the other is for economy motors found in the CR-V or Accord. The performance i-VTEC system is basically the same as the DOHC VTEC system of the B16A's, both intake and exhaust have 3 cam lobes per cylinder. However the valvetrain has the added benefit of roller rockers and continuously variable intake cam timing. The economy i-VTEC is more like the SOHC VTEC-E in that the intake cam has only two lobes, one very small and one larger, as well as no VTEC on the exhaust cam. The two types of motor are easily distiguishable by the factory rated power output: the performance motors make around 200 hp or more in stock form and the economy motors do not make much more than 160 hp from the factory.
In 2004, Honda introduced an i-VTEC V6 (an update of the venerable J-series), but in this case, i-VTEC had nothing to do with cam phasing. Instead, i-VTEC referred to Honda's cylinder deactivation technology which closes the valves on one bank of (3) cylinders during light load and low speed (below 80 mph) operation. The technology was originally introduced to the US on the Honda Odyssey Mini Van, and can now be found on the Honda Accord Hybrid and the 2006 Honda Pilot. An additional version of i-VTEC was introduced on the 2006 Honda Civic's R-series four cylinder engine. This implementation uses very small valve lifts at low rpm and light loads, in combination with large throttle openings (modulated by a drive-by-wire throttle system), to improve fuel economy by reducing pumping losses.
With the continued introduction of vastly different i-VTEC systems, one may assume that the term is now a catch-all for creative valve control technologies from Honda.
Posted: Mon Oct 16, 2006 8:15 am
by RedSun
Ok, Thx guys!
